ovrdrvn
Aug 15, 2016Aspirant
Can't Mount SMB/CIFS Shares in OS X Sierra Public Beta 4
Latest firmeware 4.4.28 and I suspect it's a Sierra issue but I see the drive and shares and am promtped to authenictate which seems to work. Trying to mount or view files results in a time out. Driv...
Aug 15, 2016Guru - Experienced User
You must mean 4.2.28
It does work with win7 and win10, so I suspect you are right in thinking it is a Sierra issue.
ovrdrvn
Aug 18, 2016Aspirant
Posted in the Apple developer forum and put in a bug report. That said, some other devlopers say SMB and NAS units are working for them but none are Netgear. I have a ReadyNAS Ultra 6 and I've tried a few tricks like turning off client negotiation on the Mac but still can't access any shares.
- StephenBAug 19, 2016Guru - Experienced User
I think that Sierra requires SMB signatures by default. Not sure if that is the problem, but you might look for a way to turn that off.
- mdgm-ntgrAug 19, 2016NETGEAR Employee Retired
That would be worth a try
Skywalker reminded me that we don't turn on SMB2 support by default on RAIDiator-x86
Samba 3.6 (which we use in RAIDiator-x86) added basic support for SMB2.
Perhaps it's required by Sierra.
You could add "max protocol = SMB2" in the global section of /etc/samba/smb.conf and restart samba to try it.
