ovrdrvn
Aug 15, 2016Aspirant
Can't Mount SMB/CIFS Shares in OS X Sierra Public Beta 4
Latest firmeware 4.4.28 and I suspect it's a Sierra issue but I see the drive and shares and am promtped to authenictate which seems to work. Trying to mount or view files results in a time out. Driv...
ovrdrvn
Aug 18, 2016Aspirant
Posted in the Apple developer forum and put in a bug report. That said, some other devlopers say SMB and NAS units are working for them but none are Netgear. I have a ReadyNAS Ultra 6 and I've tried a few tricks like turning off client negotiation on the Mac but still can't access any shares.
Aug 19, 2016Guru - Experienced User
I think that Sierra requires SMB signatures by default. Not sure if that is the problem, but you might look for a way to turn that off.
- mdgm-ntgrAug 19, 2016NETGEAR Employee Retired
That would be worth a try
Skywalker reminded me that we don't turn on SMB2 support by default on RAIDiator-x86
Samba 3.6 (which we use in RAIDiator-x86) added basic support for SMB2.
Perhaps it's required by Sierra.
You could add "max protocol = SMB2" in the global section of /etc/samba/smb.conf and restart samba to try it.
- ovrdrvnAug 22, 2016Aspirant
Do i have to ssh in to this box to do that and if so, can you point me to the link to do that? (hadnt' done it on one of these in quite some time)
