PWS442
Sep 03, 2019Guide
Check for Updates Failing
Check for updates still failing in 6.10.1 with the communication/DNS error message. Seems to be this way all year. Have to go directly to the site and download it directly (Started with 6.9.5 as prev...
- Sep 03, 2019
PWS442 wrote:
(Started with 6.9.5 as previously reported and closed.)
I'm not seeing this reported earlier in your post list.
This sounds like either the network is misconfigured (so the NAS can't reach the internet), or that the DNS server you are using isn't able to resolve update server name.
Are you using a static IP address in the NAS? Or DHCP?
Is the NTP service that syncs the time working?
Sep 03, 2019Guru - Experienced User
- PWS442Sep 03, 2019Guide
It was not my post (I searched for "Check for updates failing"), but I saw that you contributed to it. Yes, I have a static IP address, and everything else on my system seems to be working fine regarding internet access, but that message has been pretty consistent. I am set up to use the Comcast/Xfinity DNS servers at 75.75.75.75 and 76 as far as I can tell. (Note: Perhaps I mis-spoke on the DNS. Looking at the Eth1 settings, it is the same as my router at 192.168.1.254, but the router is really at 192.168.1.1. More knowledge is required I am afraid!)
YOU ARE INDEED A GOD! The .254 had to be changed to a .1. All is well! Thank you
My NAS is displaying the system from "time-e.netgear.com" just fine, I assume that is what you mean by the NTP service.
- StephenBSep 03, 2019Guru - Experienced User
Yes. Though if DNS was set incorrectly, you also wouldn't have been able to sync with the time server - so the NAS time would gradually drift off of the actual time. You might not have noticed - certainly it's easy to miss. However that should also be fixed now that the NAS has the correct DNS.
However, it wasn't until the Router address was fixed that the Updates were able to be checked. So many settings! Thanks again.
- Jul 31, 2022Retired_Member
