ummjay
Mar 18, 2022Aspirant
Check for updates not connecting
Hi all, I am suddenly having issues updating my Ready Nas 212. When I'm in the admin page, I click on check for updates, and I get an error: "Operation timeout. Communication error. Check your in...
Viffergb
May 15, 2025Luminary
Hi, for the first time in weeks, if not months, I've just logged on to my ReadyNAS 102 and thought I'd better check for any updates and I'm seeing the same error message as the OP.
Have read through the above suggestions, but can't find anything wrong with my settings, and I certainly have internet access.
Is this a case of my OLD '102' product no longer being supported, or if not, any suggestions as to what might be the cause?
Thanks in advance.
PS The current version is 6.10.10 and was last automatically updated on March 8th 2024!
May 15, 2025Guru - Experienced User
Viffergb wrote:Is this a case of my OLD '102' product no longer being supported, or if not, any suggestions as to what might be the cause?
This is an old discussion thread, and your problem has a different cause.
All ReadyNAS products are now end-of-life, and Netgear has exited the storage business. Some months back they took down their update server.
You are running the most recent (and possibly final) firmware.
- ViffergbMay 15, 2025Luminary
Thanks StephenB for clearing that up đOne other question...
I have been using the 'Microsoft OneDrive' sync option without issues, but it's been disabled (turned off) having just looked at it. Not sure when this happened...whether it was after I power cycled the NAS today, or some days ago....I've no idea, but pretty sure it worked some 7 days ago when I last did a backup of my laptop! However, if I try to enable it (turn it back on) I get the following error message..
"Unauthorized. It could be invalid user account credential or the app is not allowed to access cloud drive. Stopped syncing with One Drive."Is this also due to 'end of life' and Netgear no longer supporting syncing backups to the cloud?
Thanks again.
- StephenBMay 15, 2025Guru - Experienced User
Is this also due to 'end of life' and Netgear no longer supporting syncing backups to the cloud?It's not a feature I use, but other users have reported problems with it.
I don't know what changed, but the "End of Life" status means Netgear won't fix it.
- Jul 31, 2022Retired_Member
