Blues11's avatar
Blues11
Luminary
Oct 07, 2016
Check for updates not connecting
Usually when I click on the main page "Check for updates" it almost immeidately comes back saying "You are running the latest" or something like that.
Today it takes 5 or 10 seconds and comes back saying "Operation timeout. Communication error. Check your Internet connection or DNS Settings."
What's strange is that I can access the unit fine via ReadyCLOUD and it's operating fine on the network too.
I've made sure the static address is correct and that it's reserved in my router software. I rebooted the cable modem, the router and the NAS. I also shut off and turned back on the swtich to witch the NAS is attached.
Each time I get the same message. Any ideas?
Thank you.
  • Hello Blues11,
    The update server included 6.6.0 yesterday, that could be the reason why you were having some issues when checking for updates. Nevertheless, I am glad it works now and thank you for confirming that everything's okay now.
    To close this thread, please mark one of the posts that you think is appropriate as the solution. Please feel free to post any suggestions, comments or questions. We value your inputs and feedback.
    • JennC's avatar
      JennC
      NETGEAR Employee Retired
      Hello Blues11,
      How about adding 8.8.8.8 as DNS address in the admin page's Network > Eth 0 or 1> Settings > IPv4? Then test again.
      • viperhansa's avatar
        viperhansa
        Virtuoso
        Hi JennC,
        I tested that and it seems to work.
        I also updated to 6.6.0 and went back to my old DNS, that worked also now.
        Thanks for the support.
        Regards
        Hans
  • A friend got the same issue today after the firmware update.
    Try to disable the IPv6 support on your network interfaces.
    It solved the issue here.
ProSupport for Business
