ummjay
Mar 18, 2022Aspirant
Check for updates not connecting
Hi all, I am suddenly having issues updating my Ready Nas 212. When I'm in the admin page, I click on check for updates, and I get an error: "Operation timeout. Communication error. Check your in...
Viffergb
May 15, 2025Luminary
Thanks StephenB for clearing that up 👍One other question...
I have been using the 'Microsoft OneDrive' sync option without issues, but it's been disabled (turned off) having just looked at it. Not sure when this happened...whether it was after I power cycled the NAS today, or some days ago....I've no idea, but pretty sure it worked some 7 days ago when I last did a backup of my laptop! However, if I try to enable it (turn it back on) I get the following error message..
"Unauthorized. It could be invalid user account credential or the app is not allowed to access cloud drive. Stopped syncing with One Drive."
Is this also due to 'end of life' and Netgear no longer supporting syncing backups to the cloud?
Thanks again.
May 15, 2025Guru - Experienced User
Viffergb wrote:I have been using the 'Microsoft OneDrive' sync option without issues, but it's been disabled (turned off) having just looked at it. Not sure when this happened...whether it was after I power cycled the NAS today, or some days ago....I've no idea, but pretty sure it worked some 7 days ago when I last did a backup of my laptop! However, if I try to enable it (turn it back on) I get the following error message..
It's not a feature I use, but other users have reported problems with it.
I don't know what changed, but the "End of Life" status means Netgear won't fix it.
- Jul 31, 2022Retired_Member
