kentex
Jul 05, 2012Aspirant
CIFS won't mount after update to 4.1.9
System is ReadyNAS NV+ Running Mac OS X ver. 10.7.4 Just updated Radiator from 4.1.8 to 4.1.9. When trying to access any CIFS share, I get the error message "The operation can’t be completed beca...
p4pictures
Jul 17, 2012Aspirant
And another....
OS 10.7.4, NV+ working fine, some CIFS / AFP shares, one share that is supposed to be CIFS/AFP and has a password (all numbers due to past issues). I can access the other shares using AFP, even just going to the apple menu and recent items was enough. But I cannot connect to the password protected share at all. I am loathe to disable the password but if that is the only solution then maybe it is the one. :(
Also I see others going back to 4.1.8, is this a simple case of download the file from the page http://www.readynas.com/?cat=8 and install. Any guides on installing downgrades of firmware about?
I've had my ReadyNAS a while (Infrant kind of while) had the PSU issue but can't recall a backwards step in functionality from a new release of software ever before :slap:
p4pictures
p4pictures
