CaryTheLabelGuy
Dec 22, 2011Aspirant
CNID DB error using AFP in Lion
My rig:
late 2011 iMac 27inch 3.1Ghz Quad Core i5 running OS X Lion
ReadyNAS NV+
RAIDiator 4.1.8
4x1tb Hitachi drives
I'm having an issue whenever I try to use AFP on the ReadyNAS NV+. The problem just started happening out of the blue. I upgraded to RAIDiator 4.1.8 several weeks ago and never had a problem. The error i'm now getting is "Something wrong with the volume's CNID DB, using temporary CNID DB instead". Time machine still works perfectly and my back-ups are completing without any errors. I've read about this issue being a problem with netatalk, but I have no idea how to troubleshoot the issue or even how to restart netatalk.
For now I'm connecting with CIFS. I might just stay with CIFS and disable AFP is I can't get this issue resolved.
Thanks in advance for your help. It's greatly appreciated.
ReadyNAS NV+
RAIDiator 4.1.8
- CaryTheLabelGuyAspirantCan somebody at least explain how to restart netatalk?? I'm totally in the dark here.
- mdgm-ntgrNETGEAR Employee RetiredI would suggest you open a tech support (http://www.readynas.com/support) case. Please post your case number.
- eightpointacresAspirantI am experiencing the same issue, this is my first attempt at accessing the ReadyNas via AFP after the 4.1.8 update and my new machine is running Lion. I was able to do a time machine backup ok. But when I try to access my AFP share it gives the CNID DB error. Does anyone have a solution to make this go away and start working again?
- mdgm-ntgrNETGEAR Employee Retiredeightpointacres:
yoh-dah wrote: The AFP service in 4.1.8 updates the CNIB DB on first access, and during that access, writes are disabled on the share. If you have a ton of files in that share, it may take awhile to update the DB. Once the update process is complete, you should have full read/write access to the share. - eightpointacresAspirantmdgm,
Thanks that appears to be what was going on as this morning I was able to mount the volume in read write mode and everything is working as expected. Thank you for the prompt and informative reply. - spieAspirantI'm confused. I have this issue with the CNID DB and opened a case at netgaer support. But it seems, that netgear support is not able to provide a solution. Is this possible?
- mdgm-ntgrNETGEAR Employee Retiredspie, Is this with your Ultra?
I would suggest you start a new thread with your case number as it's likely to get more attention. - macguptaAspirantI got the CNID DB error only after a couple of weeks after upgrade to OS X Lion and RAIDiator 4.1.8
Hostname: nas-01-2E-17
Model: ReadyNAS NV+ [X-RAID]
Serial: 000da2012e17
Firmware: RAIDiator 4.1.8 [1.00a043]
Memory: 1024 MB [2.5-3-3-7]
Fortunately, rebooting the NAS solved the problem.
But if it proves necessary, how do I manage the Time Machine (ReadyNAS) volume by ftp? - sphardy1Apprentice
You can't - it is only accessible via AFP - nealjaneAspirantim having the same issue as well with our work nv+,
it seems to appear about 1 a week - CNIB DB error message.
ive restarted the server and it then goes away for a while - We cant go on with is its becoming a big issue as its being used as our work server...
