masa2
May 24, 2012Tutor
Connecting ReadyNAS Duo from Internet
Hello. I'm setting up my ReadyNAS Duo drive to my LAN and would like to be able to connect it from everywhere I want. Is it possible to do it any other way than installing ReadyNAS Remote applic...
pugilares
Jun 01, 2012Aspirant
StephenB wrote: Ok, you do have a V1. That gives you more options for remote access.
Personally I don't use WebDAV. Instead I have enabled FTP for my shares, and use FileZilla as my PC client. The Duo does support a secure FTP connection (FTP over Explicit TLS)
Secure FTP works great for me on my Duo v1 :-)
