Petesimmo
Jan 25, 2020Aspirant
Connecting Win10 laptop to RN104 via USB or Lan cable without using internet connection?
Hi
Have Naz RN104 4 bay/4TB system.
Can anyone tell me how to connect a Windows 10 laptop via USB or Lang cable without using internet connection???
Please Help.
Peter Simmonds
JohnCM_S
Feb 14, 2020NETGEAR Employee Retired
Hi Petesimmo,
You can directly connect the PC to the NAS using an Ethernet cable.
First, you will need to assign a static IP to the NAS then also assign a static IP to your laptop on the same range with the NAS.
Petesimmo
Feb 15, 2020Aspirant
Thank you for your reply.
How is that done????
Petesimmo
- StephenBFeb 15, 2020Guru - Experienced User
Petesimmo wrote:How is that done????
JohnCM_S already sketched it out.
First you'd assign a static IP to your NAS. This would be on a different subnet than your home network - for instance if your home network uses 192.168.1.x addresses, you could use a 10.0.0.2 or a 192.168.0.2 for your NAS. Set the subnet to 255.255.255.0. Set the router address to x.x.x.1 (e.g., 10.0.0.1 or 192.168.0.1 in my two examples).
Then you'd assign a x.x.x.1 IP address above to the PC ethernet port that you plan to use (as a static IP address), and connect a gigabit ethernet cable directly between the NAS and the PC.
You'll be able to access the NAS by entering the NAS IP address into the file explorer address bar (e.g., \\10.0.0.2), and you can also access the NAS's web admin interface in your browser with https://nas-ip-address/admin (e.g., https://10.0.0.2/admin).
FWIW, I don't recommend doing this unless you have a very strong privacy requirement and also have reasonable networking skills. It generally works out better if you just connect the NAS to your network, and limit access to the shares using the network access settings on the share settings wheel. If the NAS is connected to your home network, it will automatically sync time, download hot fixes and antivirus updates, and notify you when there are firmware updates.
