Skrrp
Feb 03, 2016Aspirant
Cooked NV+ (RND4000)
Model: ReadyNAS NV+ RDN4000 v3 Firmware: sticker says v4.1.7, maybe upgraded once 3 years ago Drives: 4x Western Digital Cavair Green 2TB Array: RAID 5 I've had my NV+ running for many years bu...
- Feb 03, 2016
Skrrp wrote:
I'm looking to buy a new enclosure to house my disks (I really hope they are good) but NV+'s seem to be in short supply and cost more than newer units.
Contact support. They might be willing to sell you a PSU. Warranty is 5 years, so it's possible it might still be covered. If you replace it with an RN314 or better they might also be able to provide data migration help.
Also, there was a service action some years ago, and if your serial number is within the range, they will provide a PSU even if there is no warranty.
If you do get a second hand unit, make sure you get an NV+ v1 and not a v2. Start with a scratch disk and install current firmware (4.1.14). Then power down, and migrate your disks (keeping them in the same slot).
Another option is get a new PSU. You can save some money if it is temporary (keeping the PSU out of the chassis) but you do need to modify the pinout of the stock ATX PSU
You can't directly insert the disks into a newer NAS (v2, pro/ultra or OS 6).
mdgm-ntgr
Feb 03, 2016NETGEAR Employee Retired
What's involved if you go down the route of getting a new ReadyNAS is described here: ReadyNAS: Migrating disks from RAIDiator to OS 6
At this point I wouldn't get a new Sparc NAS (your NV+ v1 hardware revision 3 is a Sparc NAS). They have been discontinued for some years and even the most cost effective of the current models is faster.
Note ReadyNAS OS 6.4.2 is now available. I would update to that using a scratch disk (must not be from your array) as described in the article above.
