Stalin66
Dec 06, 2015Aspirant
CPU temp on PRO 6 (pioneer edition) on os 6.0 - 6.4.1
Hellow all! I upgraded the OS from 4.2.28 to 6.4, and I have significantly raised the temperature of the CPU. Previously it was 35 C, now - 60! It very hot... Now, the fan speed SPU ...
walshlink
Dec 06, 2015Luminary
I have a Pro 6 with a upgraded X3230 CPU...had no problems with CPU temp spiking until 6.4.1...CPU temp climbs 25C degrees when I run scrub on my volume.
- Equinox1Dec 06, 2015Guide
walshlink...just for my curiousity. What were your normal temperatures, and with what OS version?
And what do you have now?
- walshlinkDec 06, 2015Luminary
6.4.0 sat at 48C idle...did not really climb much if at all during normal usage
6.4.1 sits at 51C idle...have not paid attention to temps for normal usage, but if I scrub volume CPU temp climbs 25C in 3 mins...not sure that is even possible to climb that fast...
Model: ReadyNAS Pro 6 (RNDP6000-200)
Upgraded CPU: Intel Xeon X3230
Memory: 4 GB
HDD: 4x Hitachi 2TB
Upgraded System Fan: Noctua NF-P12 PWM - 120mm
Upgraded CPU Fan: Noctua NF-R8 PWM - 80mm- Equinox1Dec 06, 2015Guide
Just for the record, I bought my pimped up unit (Q6600) as it is now... but the previous owner tinkered with it and the rear fan was in reverse, so I had the CPU constantly at 80-85 degrees, and went up to 105 degrees under load.
I reversed the rear fan, then I got immediately to numbers that are very similar to yours.
