Stalin66
Dec 06, 2015Aspirant
CPU temp on PRO 6 (pioneer edition) on os 6.0 - 6.4.1
Hellow all! I upgraded the OS from 4.2.28 to 6.4, and I have significantly raised the temperature of the CPU. Previously it was 35 C, now - 60! It very hot... Now, the fan speed SPU ...
Equinox1
Dec 06, 2015Guide
walshlink...just for my curiousity. What were your normal temperatures, and with what OS version?
And what do you have now?
walshlink
Dec 06, 2015Luminary
6.4.0 sat at 48C idle...did not really climb much if at all during normal usage
6.4.1 sits at 51C idle...have not paid attention to temps for normal usage, but if I scrub volume CPU temp climbs 25C in 3 mins...not sure that is even possible to climb that fast...
Model: ReadyNAS Pro 6 (RNDP6000-200)
Upgraded CPU: Intel Xeon X3230
Memory: 4 GB
HDD: 4x Hitachi 2TB
Upgraded System Fan: Noctua NF-P12 PWM - 120mm
Upgraded CPU Fan: Noctua NF-R8 PWM - 80mm
- Equinox1Dec 06, 2015Guide
Just for the record, I bought my pimped up unit (Q6600) as it is now... but the previous owner tinkered with it and the rear fan was in reverse, so I had the CPU constantly at 80-85 degrees, and went up to 105 degrees under load.
I reversed the rear fan, then I got immediately to numbers that are very similar to yours. - AmosNZDec 06, 2015Aspirant
My RNP6 with E7500 CPU still runs mid 30 deg C at idle under 6.4.1. Temp can increase very quickly when under load (up to 50deg in less than 2 minutes), but then my CPU fan ramps up to 3500 rpm and controls it.
Edit - actually if I run stress on multiple cores the cpu temp can jump to 55+ within a minute. That got the cpu fan up to 4200rpm.
- dsm1212Dec 06, 2015Apprentice
My E7600 pro-6 idles at about 37 deg. One thing that I done a couple of times is open it and blow out the cpu cooler and fan. That thing seems to collect a lot of dust in my house.
steve
- mdgm-ntgrDec 06, 2015NETGEAR Employee Retired
You can override the minimum fan speed with a higher setting by creating a flag file with the value you want as has been mentioned before.
