Stalin66
Dec 06, 2015Aspirant
CPU temp on PRO 6 (pioneer edition) on os 6.0 - 6.4.1
Hellow all! I upgraded the OS from 4.2.28 to 6.4, and I have significantly raised the temperature of the CPU. Previously it was 35 C, now - 60! It very hot... Now, the fan speed SPU ...
Dec 27, 2015Guru - Experienced User
viperhansa wrote:
Can you assist us newbees :-) to how and where to create the flag file to raise the minimum fan speeds? Please? :-D
From SSH.
# echo 1200 > /etc/frontview/min_fan_speed_override
sets the minimum fan speed to 1200 rpm.
walshlink
Dec 27, 2015Luminary
StephenB,
Which fans? Both CPU and system fans?
- walshlinkDec 27, 2015Luminary
Does anyone know if the CPU fan on the RNP 6 is designed to suck air in or blow air out? I had it installed to blow air out and temps would be very high. I reversed it to suck air in and it is nice and cool now.
