bishoptf
Feb 11, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like debian to me, kernel 2.6.37) I'm a *nix guy so I thought I would try to make an all inclusive step-by-step to help anyone that might want to try and install crashplan. So here goes, the normal warning goes here - There are no warranties implied or otherwise, DO THIS AT YOUR OWN RISK! If you find any thing that needs to be updated or doesn't make sense please post and let me know...
I am not the only one to post how to do this see here - http://www.readynas.com/forum/viewtopic.php?f=61&t=18139&start=15#p297737
and here http://support.crashplan.com/doku.php/how_to/configure_a_headless_client
Steps for x86 ReadyNas Only:
Old way,still works but uses java 6, which is out of date:
Updated JAVA install, credit goes to InterClaw :)
The full instructions can be found here - http://minimserver.com/ejre-installer.html I will try to list just the steps for x86 ReadyNas:
1. Go to Oracle and down load the latest embeeded java version l@@k for this version - x86 Linux Small Footprint – Headless - http://www.oracle.com/technetwork/java/embedded/downloads/javase/index.html
*Note you will have to accept Oracles Terms and Conditions and create an account to download the file
2. Download file and copy the java file to /c/backup/ on your ReadyNas
3. Download the EJRE Readynas Addon see the link above for the full instructions, the addon can be found here - http://minimserver.com/downloads/EJREInstaller-0.10-readynas-x86.bin
4. Install EJRE Addon and this will install the java version that you placed in /c/backup/
5. Verify that java is working, time to jump to the command line to finish the installation. Install the Enable Root SSH addon - http://www.readynas.com/download/addons/x86/4.2/EnableRootSSH_1.0-x86.bin Complete installation by rebooting your readynas.
6. You will need to get a ssh client for your desktop/laptop, here is one for winblows (putty) - http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe, nothing to install, just download and place on your desktop or somewhere you can find it.
7. Open putty and SSH into your readynas, enter the IP address and when it prompts for username enter "root" and then your normal raidar/frontpage "password". Once logged in verify java operation by entering the following :
8. Now we can install Crashplan.
- Download the latest linux crashplan version
enter "wget the latest version that is listed on crashplan for linux, see below"
Here is the main download page, just make sure you get the latest version -
http://www.crashplan.com/consumer/download.html?os=Linux, this will download andplace this in your
root directory.
9. Once the diownload has completed lets extract the files which are tarred and zipped.
enter "tar -xvf CrashPlan_3.0.3_Linux.tgz" or whichever version you downloaded, this will extract all of the files
and place them in a folder called "CrashPlan-install".
enter "cd "CrashPlan-install" and then run the installer, enter "./install.sh", this will start the installer
ask for you to accept the terms and conditions and ask questions where to install etc..You can accept the defaults
for most, however when it prompts you for the default crashplan backup directory, you can go with the default or
provide a directory that you have already established for that purpose, e.g., "/crash-backup" whatever your share
that you created without any slashes, this actual is a pointer to "crash-backup -> /c/crashplan-backup"
Here are the questions, most you accept the defaults, in this case I chose to specify a different Directory -
Do you accept and agree to be bound by the EULA? (yes/no) yes
What directory do you wish to install CrashPlan to? [/usr/local/crashplan]
What directory do you wish to link the CrashPlan executable to? [/usr/local/bin]
What directory do you wish to store backups in? [/usr/local/var/crashplan] /crash-backup
What directory contains your SYSV init scripts? [/etc/init.d]
What directory contains your runlevel init links? [/etc/rc2.d]
Your selections:
CrashPlan will install to: /usr/local/crashplan
And put links to binaries in: /usr/local/bin
And store datas in: /crash-backup
Your init.d dir is: /etc/init.d
Your current runlevel directory is: /etc/rc2.d
Is this correct? (y/n) [y] y
10. Configure crashplan on the readynas, in order to do this you need to download and install crashplan on a local PC,
using linux, winblows or Mac - http://www.crashplan.com/consumer/download.html once that has been
done we need to tunnel from the PC to the readynas, the already have this detailed on the crashplan site
called a headless install - http://support.crashplan.com/doku.php/how_to/configure_a_headless_client
*Note while configuring the Crashplan client -the client will show your shares twice - as links (with an arrow as part of the icon)
and under the "C" folder. It won't back up the links, you need to select the folders under the "C" folder. If you try the other way, the
backup "succeeds", but doesn't back anything up. Thanks to StephenB for this update!
Once the configuration is complete you should be good to go.. :)
I'm sure I have left something out or not fully explained something, if so let me knoiw and I will update the posting..
Good Luck :)
1. See Step one below
2. See Step two below
3. See Step three below
4. Once logged onto your readynas as "root" your ready to get the the software setup. Keep in mind that when you are running as root, you have elevated priviliges and you can do anything you want, including messing things up, so go slow and take your time :)
- First thing we need to do is edit the sources.list, we are going to use vi which is not a friendly editor
but is installed on any base *nix system and in this case will get the job done. Lets edit the file, at
the prompt - vi /etc/apt/sources.list, arrow down to the last line and then arrow over to the
last letter and hit the "a" button for append and then hit "enter" to get a new line and then paste
"deb http://archive.debian.org/debian-backports etch-backports main non-free" .
- To get out of vi and save the file "shift:" will get you the colon prompt at the bottom, then to save
and exit enter "x", if you made a mistake and you do not want to save your work at the colon enter "q!"
and that will quit without saving any changes. Once you exit and save your sources list should look
like this, "more /etc/apt/sources.list" -
deb http://www.readynas.com/packages 4.2.19/
deb http://archive.debian.org/debian etch main
5. Now we need to update our package list and install Java.
- enter "apt-get update"
- Now we need to modify configuration dialog selection so we can accept the java Terms and conditions.
- enter "dpkg-reconfigure debconf"
This will ask you to select a dialong frontend, select option 1 - Dialog, then it will ask you for
the level, select option 3 - Medium.
- Now lets install java, enter "apt-get install sun-java6-jre", it will download the package and start to
install it where it will ask for you to accept the terms and conditions, select yes and complete the
installation.
- Modify the deb configuration and change it back, enter "dpkg-reconfigure debconf"
This will ask you to select a dialong frontend, select option 6 - Noninteractive, then it will
ask you for the level, select option 3 - Medium (not sure if this was the default).
java -version
root directory.
Your selections:
Good Luck :)
- AnonymousThanks depasseg for your excellent instructions.
On this bit...depasseg wrote: Great writeup. I added a couple things - like installing Nano rather than using vi and also including instructions to configure the headless monitoring:
* Install RootSSH Add-on
* Reboot
* SSH as root
* run: Apt-get update
...I had to use lower case "apt-get update"depasseg wrote:
* On your computer (the one you want to control your NAS backups from), look for a file called ui.properties in c:\Program Files\CrashPlan\conf
* Edit the file and uncomment (delete the #) the serviceHost line and replace 127.0.0.1 with the IP of your NAS (for instance 192.168.1.100).
Just wondering how to make it work so that I can control 2 NASs on my lan? The easiest way is probably to install the desktop app on another pc with the IP of the 2nd NAS in the ui.properties file, but I'm just wondering if those familiar with crashplan know of a way to make it work from one PC? - StephenBGuru - Experienced User
Use bishoptf's original instructions (based on Crashplan's guide: http://support.crashplan.com/doku.php/h ... ess_client)kc1 wrote: Just wondering how to make it work so that I can control 2 NASs on my lan? The easiest way is probably to install the desktop app on another pc with the IP of the 2nd NAS in the ui.properties file, but I'm just wondering if those familiar with crashplan know of a way to make it work from one PC?
In short, leave the serviceHost line commented out in ui.properties and set servicePort to 4200 instead.
Then set up ssh profiles in putty for each NAS. Connect to the NAS you want to manage with Putty, then launch the crashplan client. When switching to the other NAS you exit the client, change the putty connection, and launch it again. (failing to exit the client is not fatal, it will error out). - Anonymous
StephenB wrote: Use bishoptf's original instructions (based on Crashplan's guide: http://support.crashplan.com/doku.php/h ... ess_client)
Thanks, I got stuck at this bit when I tried those:
, because these commands are recognised by Windows (my desktop PC), and I don't know what the equivalent is.http://support.crashplan.com/doku.php/how_to/configure_a_headless_client wrote: Open a terminal window on 1.1.1.1.
Using SSH, forward port 4200 on 1.1.1.1 to port 4243 on 2.2.2.2.
The command is:
ssh -L 4200:localhost:4243 yourusername@2.2.2.2 - mdgm-ntgrNETGEAR Employee RetiredUse a free program called PuTTy to SSH in.
Choose SSH and enter the host 2.2.2.2 (replace the 2.2.2.2 with the actual IP address of the device).
Then go to the menus on the side panel. One of the options there will allow you to do the tunnel configuration.
Source Port: 4200
Destination: localhost:4243
Then click Add (don't forget to do this step)
then connect. - AnonymousThanks, I thought it worked but spoke too soon:
After setting up the tunnel in PuTTY, and logging in, CrashPlan doesn't connect, and telnet says:
NVX:~# telnet localhost 4200
telnet: can't connect to remote host (127.0.0.1): Connection refused - AnonymousWorking after I remembered to set ServiceHost back to 127.0.0.1 in /usr/local/crashplan/conf/my.service.xml.
Thanks all - skim32TutorCan someone clarify something for me. Does this allow the readynas to directly backup to Crashplan without a computer running? Or do I still need a desktop running?
- sphardy1ApprenticeNo additional computer needed except to configure CP on the NAS. Data is then backed up from your NAS to the selected destination directly
- skim32Tutor
sphardy wrote: No additional computer needed except to configure CP on the NAS. Data is then backed up from your NAS to the selected destination directly
Great. Gonna give it a go tonight. Can anyone comment on how well the Readynas runs Crashplan? Does it take a lot of system resources? Is a RAM upgrade recommended? I have ReadyNas Ultra 4 Plus running stock. - f41yazAspirantHi all,
I just brought a readynas ultra 2 last week and have been trying even since to set up crashplan on it but it just does not work.
I believe i have installed crashplan on the nas via putty properly but cannot work out how to do the port forwarding.
I am getting the following message: telnet: can't connect to remote host (127.0.0.1): Connection refused
and i have tried eveything but cannot seem to get the nas to show up on my crashplan desktop.
it would be great if someone out there could help me to set up crashplan on my nas pleaseee:D
i am not a linux user and this is my first time using putty and doing something like this.
hope to hear from someone soon :D
