getads
Dec 28, 2015Aspirant
Data Degraded but Volumes are fine?
Hi there, I've had a ReadyNAS 314 taking care of my Time Machine backups for around 2 years now with no problems. Currently, the ReadyNAS LED is flashing "data ; Degraded" so I had a look ins...
- Dec 28, 2015
If you hover your mouse over the disk you should see some stats.
Your logs show that disk 3 (one of your WD20EARS disks) has failed. It has 945 reallocated sectors and a current pending sector count of 695. I would suggest replacing this e.g. with a WD20EFRX.
Your smart_history.log would suggest this disk was failing possibly as far back as April. Certainly by May/June.Do you have a backup?
mdgm-ntgr
Dec 28, 2015NETGEAR Employee Retired
Do the SMART stats for your disks look fine?
Can you send in your logs (see the Sending Logs link in my sig)?
getads
Thanks mdgm,
Just sent you my logs via email.
Not sure what the Smart stats are for the disks? Apart from the yellow 'degraded' alert, there is nothing else in any interface that looks like a problem?
