jimcocteau
Jul 16, 2018Guide
Data Degraded Error
Hi,
I have just had a reboot and my system is giving a "Data Degraded" registering, I did get a "Disk 3 Error" and was about to backup and replace the disk when the "Data Degared' error occured...
- Jul 19, 2018
Hi jimcocteau
The logs sent was before the disk was replaced right? What is the progress of the re-sync now? were you able to get the serial number of the replacement and the drive you replaced? Kindly PM me if it's available.
Re-sync once completed should get your NAS back to normal.
Regards
jimcocteau
Jul 17, 2018Guide
Hi Mark_V,
I have worked out I can replace the disk (I do have a spare, same size and type, it has been used in my other unit and will require formating when I install but should be fine. The logs are indicating disk three is the only one degraded so with my configuration as Raid5 with four disks I should be able to resync all files.
Can I just replace with out powering down?
Thanks,
jimcocteau
Marc_V
Jul 17, 2018NETGEAR Employee Retired
Hi jimcocteau
Yes, ReadyNAS supports hot swap so you don't need to power down the device when you replace a disk.
Please see How do I replace a disk in my ReadyNAS OS 6
Hope this helps!
Regards
