jimcocteau
Jul 16, 2018Guide
Data Degraded Error
Hi,
I have just had a reboot and my system is giving a "Data Degraded" registering, I did get a "Disk 3 Error" and was about to backup and replace the disk when the "Data Degared' error occured...
- Jul 19, 2018
Hi jimcocteau
The logs sent was before the disk was replaced right? What is the progress of the re-sync now? were you able to get the serial number of the replacement and the drive you replaced? Kindly PM me if it's available.
Re-sync once completed should get your NAS back to normal.
Regards
jimcocteau
Jul 17, 2018Guide
Hi Mark_V,
I have replaced the disk, its a JBOD that I used in my other unit, as attached photo, can I destroy or somhow reformat and then add to my RAID5, I have not rebooted as yet. I will also send logs as per insructions.
If not I will have to power down and obtain a new Disk?
Thanks
Jim
Marc_V
Jul 19, 2018NETGEAR Employee Retired
Hi jimcocteau
Regards
- jimcocteauJul 19, 2018Guide
Hi Marc_V,
Disk Details:
Tue Jul 17 2018 20:57:25 Disk: Disk Model:ST4000VN000-1H4168 Serial:Z300VEY8 was added to Channel 3 of the head unit. I have also sent uptodate logs, the resync is at 61.14% time left 32.41.22
Thanks,
jim
- jimcocteauJul 20, 2018Guide
All is back online and volumes seem fine.
Thanks to Marc_V and all.
Jim
