TeknoJnky
Jan 10, 2017Hero
data degraded, however resync completed
I was upgrading other devices drives and I swapped a good working drive in my ultra 4 (6.6.1), the volume resynced completed, however then it says degraded. All drive lights are green on the volu...
- Jan 10, 2017
Sounds like removing disk 3 and readding it after a minute would be the way forward, yes.
It's weird that it failed to rotate the journal when there is so much free space on the 4GB root volume.
TeknoJnky
Jan 10, 2017Hero
Physical disk 3 is the one I had swapped, both disks are good, I just swapped a seagate 4tb to a hitachi 4tb, all disks are now hitachi 4tb.
From mdstat.log
md126 : active raid5 sda4[0] sdd4[3] sdb4[1]
5860124736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [UU_U]
md127 : active raid5 sda3[4] sdd3[7] sdc3[8] sdb3[5]
5845988352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
bitmap: 0/15 pages [0KB], 65536KB chunkIt looks like I am missing disk 3 (sdc4) on md126?
/dev/md/data-1:
Version : 1.2
Creation Time : Wed Jul 20 14:21:51 2016
Raid Level : raid5
Array Size : 5860124736 (5588.65 GiB 6000.77 GB)
Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB)
Raid Devices : 4
Total Devices : 3
Persistence : Superblock is persistent
Update Time : Tue Jan 10 20:53:03 2017
State : clean, degraded
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Name : 3faa22ed:data-1 (local to host 3faa22ed)
UUID : 79643dbe:e57091f6:8324232a:d425c1a0
Events : 9049
Number Major Minor RaidDevice State
0 8 4 0 active sync /dev/sda4
1 8 20 1 active sync /dev/sdb4
4 0 0 4 removed
3 8 52 3 active sync /dev/sdd4So, safe to remove, wait a minute, then re-add disk 3 ?
Or should I run some command to force resync on md126 ?
mdgm-ntgr
Jan 10, 2017NETGEAR Employee Retired
- TeknoJnkyJan 10, 2017Hero
Ok giving it a shot, thanks for the confirmation.
While browsing the various logs, I saw a few different errors related to disk full or to that effect.
edit: ok it's resyncing again. Hopefully it will finish cleanly this time.
thank you again!
- TeknoJnkyJan 11, 2017Hero
yay!
Wed Jan 11 2017 9:30:44 Volume: Volume data health changed from Degraded to Redundant. Wed Jan 11 2017 9:30:39 Volume: Volume data is resynced.
