njpryan
Apr 02, 2015Aspirant
Data: DEGRADED on RN104
Hi guys, extreme help required. Added a second 4TB WD RED into slot 2 of my RN104 NAS tonight and everything started off ok and then suddenly I have the following flashing at me every few seconds.. ...
mdgm-ntgr
Apr 03, 2015NETGEAR Employee Retired
Well if you can't backup your data it clearly is not that important. No important data should be stored on just the one device.
If the drive is O.K. you could delete the partitions off it and try adding it again (to the same slot as before). If it is bad you would need another disk.
Adding the second disk would add redundancy. Using X-RAID you could then add a third disk to expand the volume.
