njpryan
Apr 02, 2015Aspirant
Data: DEGRADED on RN104
Hi guys, extreme help required. Added a second 4TB WD RED into slot 2 of my RN104 NAS tonight and everything started off ok and then suddenly I have the following flashing at me every few seconds.. ...
Apr 07, 2015Guru - Experienced User
You were using xraid, so when you added a disk it converted to raid-1. When you remove a disk it becomes degraded raid-1, not jbod. Unfortunately if you want to go back to jbod you need to destroy the volume and create a new one. Then restore the data from backup.
