njpryan
Apr 02, 2015Aspirant
Data: DEGRADED on RN104
Hi guys, extreme help required. Added a second 4TB WD RED into slot 2 of my RN104 NAS tonight and everything started off ok and then suddenly I have the following flashing at me every few seconds.. ...
njpryan
May 28, 2015Aspirant
Hi StephenB,
Again it's been another while and everything is still the same with regards to my RN104 - Slot 1 (4TB), Slot 2 (4TB) and currently RAID-1
I have noticed of late that the space available has suddenly increased from 2GB (approx) to 4GB (approx) for no apparent reason. Also on a more scary note I keep losing connection to the RN104 on the web (ip192.168.1.1) - keep getting the server is currently busy and I click on re-connect but same issue. Any ideas ?
I can still connect to it to add files etc but using the readynas software to connect and get the logs etc - not happening. I did carry out a restart and this worked for about 5 mins and then the RN104 started updating files and the connection was interrupted again on the web access but continues to work by adding files through the normal network.
With regards to the earlier conversation about RAID-1 and RAID-5 when I add the third 4TB drive - what is going to happen - e.g. will I have 12TB of storage or 8TB of storage and 4TB(slot 2) remains backup of Slot 1 - sorry in advance for seeming confused and repeating some questions.
Regards
NJP
Regards
NJP
