michelefaccini
Dec 24, 2011Aspirant
DEFRAG ON READYNAS ULTRA 2 PLUS ?
Hi everybody.....I would like to know if it's possible and or necessary to do defragmentation on the NAS's disks ? If yes, is there a specific tool to use ? I can't launch defrag from my desktop bec...
mdgm-ntgr
Dec 24, 2011NETGEAR Employee Retired
michelefaccini wrote: Why so is it so called expandable raid ?
You can add additional disks to empty drive bays (horizontal expansion and will only give expansion in 4-bay or greater ReadyNAS as adding a second disk to a single disk array adds redundancy) or replace disks with higher capacity ones (vertical expansion, will give expansion in all ReadyNAS).
See X-RAID2 in Action
