jerry_va1
Oct 22, 2014Aspirant
Descent2 hardware failure-System Error Pls Contact Cust Sppt
Dear Forum, Is this ReadyNAS NV+ toast? 1. WINDOWS REPORTS "LOCAL SECURITY AUTHORITY ... INCONSISTENCY" My ReadyNAS NV+ (RAIDiator 4.1.12; another NV+ is running 4.1.14 ) spontaneously caused...
jerry_va1
Thank you, the shares are back, FrontView looks normal.
There is no access on Windows (one machine checked) -- the ReadyNAS does not present itself to the homeLAN WIndows Workgroup.
On MacBook Finder, CIFS access is only possible if I do not come in as guest (I want this), but instead give the ReadyNAS user=admin & password=remote admin pwd.
PASSWORDS / DOMAINS
Is it true that I can never change the ReadyNAS shares to accept my homeLAN user "Jerry" and homeLAN pwd for jerry instead of "admin" and the ReadyNAS admin pwd?
If true, then I must have guest access on the ReadyNAS. Of course I checked "guest" when implementing wide open USER-mode access . . .
Is there something I should check and discard to keep the OS partition happy? I discarded logs recently . . .
PASSWORDS / DOMAINS
