martin9911
Sep 01, 2016Aspirant
Difference in available storage space between WebGUI and Finder(AFP)
Running 6.5
A couple of weeks ago I removed a "private time machine" allocating roughly 500Gb. The avaialabe storage in the WebGUI differs about 500Gb compared to what I can see in Finder, mounting a AFP-share.
Any idéas?
/Martin
The NAS uses base 2 (like most PCs) whereas the Mac uses base 10. So you will get a larger number on your Mac but the amount of free storage is the same.
Also the Time Machine tab won't let you set a quota that is as large as all of the remaining space (it's not advisable to completely fill a volume).
Try running a balance
- mdgm-ntgrNETGEAR Employee Retired
What numbers do each report? And how much space is on the volume?
- martin9911Aspirant
A balance did not fix it...
I´m doing a huge sorting of my data, all across my computers, external drives and the NAS.
This problem came when i removed a private time machine and I´ll soon be doing it again.
Can I fix this some way and how do I remove private time machine the right way so this does not happen again?
/Martin
- martin9911AspirantSo it's just a coincidence that the size of my deleted time machine matches with base 2 vs base 10?
Even though I never seen any difference in available space before?- mdgm-ntgrNETGEAR Employee Retired
Base 2 to Base 10 conversion would be e.g.
1GiB (base 10) = 1024 ^ 3 / 1000 ^ 3 GB (base 2)
Disk manufacturers and Macs use base 10 whereas most PCs use base 2. PCs tend to call GiB, GB.- martin9911Aspirant
That´s not the case for me. Using your formula and to my current numbers:
NAS Webgui 2,95TB equals 3,021TB. Finder shows 3,24TB.
EDIT: I stand corrected! I was wrong, mdgm was right!
