Retired_Member
Jun 27, 2013Disk mount x86 in Linux LVM HELP
So I have a readynas ultra 2 with 2 TB drives that got that whole "Missing shares error" thing. So I thought that I would take one of the drives, mount it in linux (ive done this b4), and reset the o...
Retired_Member
Jul 02, 2013Please ignore the mount device name. These were during different logins. sda, sdb, and sdc from the first post are all the first drive from the array.
mdadm -E output for all partitions:
Important:
gdisk output:
Ill get the logs when i can.
As far as I can tell, I had power loss during a resync of the drives, so now I have a bad sector and the second drive is stuck as a spare.
root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb
/dev/sdb:
MBR Magic : aa55
Partition[0] : 3907029167 sectors at 1 (type ee)
root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb3
mdadm: No md superblock detected on /dev/sdb3.
root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb1
/dev/sdb1:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 494a7e99:7972ebcc:9b4a1bd1:d55a1de3
Creation Time : Thu Sep 8 16:33:41 2011
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 8386560 (4.00 GiB 4.29 GB)
Array Size : 4193268 (4.00 GiB 4.29 GB)
Used Dev Size : 8386536 (4.00 GiB 4.29 GB)
Data Offset : 2048 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 57b9a1e6:9daba6b6:7246f828:f2af845a
Update Time : Tue Jul 2 01:31:50 2013
Checksum : 2bcb3495 - correct
Events : 476276
Device Role : Active device 0
Array State : A. ('A' == active, '.' == missing)
root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb2
/dev/sdb2:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 16b0093f:e9ce8e55:6f550c64:9f57fbf3
Creation Time : Thu Sep 8 16:33:42 2011
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 1048552 (512.07 MiB 536.86 MB)
Array Size : 524276 (512.07 MiB 536.86 MB)
Data Offset : 24 sectors
State : clean
Device UUID : cdbaf0c1:7d3f99a3:37786b19:3f1e936a
Update Time : Thu Jun 27 21:49:16 2013
Checksum : c59f7e50 - correct
Events : 255
Important:
gdisk output:
root@ubuntu:/home/ubuntu# gdisk
GPT fdisk (gdisk) version 0.8.1
Type device filename, or press <Enter> to exit: /dev/sda
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Command (? for help): p
Disk /dev/sda: 3907029168 sectors, 1.8 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): D2AD91F6-ED10-451B-8466-36F3A01BFE2D
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 64-sector boundaries
Total free space is 4092 sectors (2.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
3 9437248 3907025072 1.8 TiB FD00
Command (? for help): i
Partition number (1-3): 1
Partition GUID code: A19D880F-05FC-4D3B-A006-743F0F84911E (Linux RAID)
Partition unique GUID: 29CFC302-D112-423D-BA26-B50B9F733F25
First sector: 64 (at 32.0 KiB)
Last sector: 8388671 (at 4.0 GiB)
Partition size: 8388608 sectors (4.0 GiB)
Attribute flags: 0000000000000000
Partition name: ''
Partition number (1-3): 2
Partition unique GUID: B3B52523-2065-46AC-8D71-C802C2FBD618
First sector: 8388672 (at 4.0 GiB)
Last sector: 9437247 (at 4.5 GiB)
Partition size: 1048576 sectors (512.0 MiB)
Partition name: ''
Partition number (1-3): 3
Partition unique GUID: 08A311D3-C961-4449-9CB1-B0BD32D9B39D
First sector: 9437248 (at 4.5 GiB)
Last sector: 3907025072 (at 1.8 TiB)
Partition size: 3897587825 sectors (1.8 TiB)
Partition name: ''
