OOM-9
Jan 07, 2012NETGEAR Expert
Domain Join Issue - Information
I have found some helpful information for people that have issues joining the domain. The points to check when configuring the ReadyNAS to join the domain, and an additional option with logs to see why it is not able to join the domain.
Basic configurations should be checked:
There is a log option that you can use when joining an ADS known as the “domain_join.log”.
Logs downloaded from Frontview- /Status/Logs/ (top-right) 'Download All Logs'
Bottom of this log shows addition information with the following circumstances:
When you have a bad username or password:
When you have a bad NetBIOS Name:
I have noticed that this is not always the name of the server, but can also be the sub-domain name for the server.
When you have a bad Domain Name (FQDN):
Example Logs were based on the following (security mode) domain configuration:
Domain Type: ADS
NetBIOS Name: MY
Domain Name (FQDN): MY.DOMAIN.LOCAL
Note on the log:
I have seen in some scenarios were the domain_join.log not show up, but switching the domain to user mode and back to domain mode helps generate this log.
- Routes - Check to see if the server is able to access the ReadyNAS
DNS - Configure one of the DNS Settings to the Local domain server
NTP - Configure to the NTP to the domain server or same NTP server as the domain
Domain settings - Make sure the security mode settings are matching the domain that is being joined
Failed to join domain: failed to lookup DC info for domain 'MY.DOMAIN.LOCAL' over rpc: Logon failure
Failed to join domain: Invalid configuration ("workgroup" set to 'YOUR', should be 'MY') and configuration modification was not requested
Failed to join domain: failed to find DC for domain MY.DOMAIN.LOCAL2
Domain Type: ADS
NetBIOS Name: MY
Note on the log:
- guitmanAspirantEven with no OU specified, I receive the error with no message or code. I have checked everything, time is synced, DNS is correct.
I downloaded all logs, but domain_join.log is not present, does this have to be enabled?
Using 6.1.9 - mdgm-ntgrNETGEAR Employee Retiredguitman have you tried contacting support?
- guitmanAspirantNot yet, thought I would try the forums first.
- bobertinAspirantHey,
I can't find any solution to connect a readyNas 102 to AD.
I've no error code, no error message, just the "security settings failed to apply".
Is a windows server message, a ready nas message???
What I'm doing wrong?
Thank you for your tips and sorry formy bad english! - terryvellaAspirantHi, firstly please excuse me if I'm posting incorrectly here. I have 2 x ReadyNas 2120 and 1 x 104 all of which are successfully authenticated on my domain. The problem I have though is with the 104; it fails the ADS accounts refresh and says "Import Error" Under Authentication. All the AD users are available but only one group is imported; "Domain users". The 2120's are not affected
All three boxes are running 6.2.2 and are configured the same as each other as far as I can see but whatever I do I can't complete the authentication process without the import error on the 104. The two 2120's authenticate correctly and all 3 synch their times with the same server.
Any pointers?
Thanks - mdgm-ntgrNETGEAR Employee RetiredHave you tried backing up your data and doing a factory default (wipes all data, settings, everything) and then attempting to complete the authentication process?
- mjwiseAspirant
terryvella wrote: Hi, firstly please excuse me if I'm posting incorrectly here. I have 2 x ReadyNas 2120 and 1 x 104 all of which are successfully authenticated on my domain. The problem I have though is with the 104; it fails the ADS accounts refresh and says "Import Error" Under Authentication. All the AD users are available but only one group is imported; "Domain users". The 2120's are not affected
Any pointers?
Thanks
For what it's worth, I get the same error with a 516 on 6.2.2 if you run the ADS refresh. "Domain Users" is the only group that shows up as imported. That's basically the only group we use, so it's not a big deal, but AD support seems half-baked at best under 6.2.2. - brianmAspirantI used to have the same issue, however since upgrading to BETA 6.3.3-T149 all AD users and all AD groups are returned and displayed.
- KevinB15AspirantHave been having the same problem. Support found that "/etc/passwd" and "/etc/group" files were corrupted. They fixed it, but it only worked for a day or so, now I'm back to getting the same error message again.
