zeipet
Oct 09, 2015Aspirant
Downgrade RN104 from 6.4.0 to 6.2.X Possible? USB Driver for PCTV 461e and serialusb do not work
Today i´ve purchased the V5 License AND installed the ReadyNAS 6.4.0 (System Break due App uninstall on 6.2.2, so i had to upgrade) However, The OS works fine but the Stick for DVBLink will no longe...
kohdee
Oct 09, 2015NETGEAR Expert
You can't downgrade from 6.4 to 6.2, as 6.4 enables quotas on the file system, something 6.2 cannot support. Also, many database changes were made, so downgrading won't understand those new changes either. Upgrading to 6.4 also changes the bootloader.
Kortus
Oct 11, 2015Aspirant
Sorry I made mistake....
I have the same problem when I made upgrade from 6.2.4 to 6.4.0 the DVBlink SW don´t see my PCTV 73se connected in USB port. Will you do some patch for resolve this problem?
- zeipetOct 15, 2015Aspirant
Take a look to DVBlogic Forum... I made a post with a solution which worked for me.
http://forum.dvblogic.com/viewtopic.php?f=76&t=30378&p=107742#p107742
- KortusOct 15, 2015Aspirant
Thank you for response and link. Unfortunately I have ReadyNas with x86 processor (312) and I cannot use your kernelmodules
