zeipet
Oct 09, 2015Aspirant
Downgrade RN104 from 6.4.0 to 6.2.X Possible? USB Driver for PCTV 461e and serialusb do not work
Today i´ve purchased the V5 License AND installed the ReadyNAS 6.4.0 (System Break due App uninstall on 6.2.2, so i had to upgrade) However, The OS works fine but the Stick for DVBLink will no longe...
Kortus
Oct 11, 2015Aspirant
Sorry I made mistake....
I have the same problem when I made upgrade from 6.2.4 to 6.4.0 the DVBlink SW don´t see my PCTV 73se connected in USB port. Will you do some patch for resolve this problem?
zeipet
Oct 15, 2015Aspirant
Kortus wrote:Sorry I made mistake....
Take a look to DVBlogic Forum... I made a post with a solution which worked for me.
http://forum.dvblogic.com/viewtopic.php?f=76&t=30378&p=107742#p107742
- KortusOct 15, 2015Aspirant
Thank you for response and link. Unfortunately I have ReadyNas with x86 processor (312) and I cannot use your kernelmodules
