DoctorBrown
Nov 30, 2022Apprentice
Downgrading ReadyNAS firmware from 6.10.x - Redux
I know this subject has been covered in the past, but almost all the articles are from many years ago. And none are helpful for my issue. I've been using my reliable ReadyNAS 102 for many years now. ...
DoctorBrown
Dec 03, 2022Apprentice
Sandshark.
Thank you for the very useful info. It seems unwise to try to downgrade this any further.
Is there anything you can think of that I might do to figure out why my NAS is so slow? I've ssh'd into the NAS and used top to monitor the CPU usage and it's very high when using Windows Explorer to copy large files, about 90%.
I'm at a loss to figure this out.
Sandshark
Dec 04, 2022Sensei
Your NAS is slow because the 100 series are the least capable OS6 based ReadyNAS. Both the processor and RAM are limitations. I suppose it's possible that the upgrade to OS6.10.x used enough additional memory that everything slowed down. Do you have any apps running? Disabling them might help.
- DoctorBrownDec 04, 2022Apprentice
Sandshark wrote:..... I suppose it's possible that the upgrade to OS6.10.x used enough additional memory that everything slowed down. Do you have any apps running? Disabling them might help.Thanks for replying. That's what I'm considering about the upgrade. The system does seem CPU limited. And no, I don't have any apps running. The confounding thing is I'm chatting with someone in another thread that has the exact same CPU and Upgrade and he's getting 70MB/s.
- StephenBDec 04, 2022Guru - Experienced User
Sure, but DoctorBrown's NAS is much slower than my RN102, so there is something going on.
I am wondering if enabling flow control in the pc (and the switches if they have that option) would help. It's possible that packet overruns in the NAS might be part of the puzzle.
Also, I have jumbo frames disabled on my network, so that might also be part of the puzzle.
I have more data. I ssh'd into the system and ran htop to monitor the CPU and Memory usage. Here's the data
All these test were done using a 1 GB file. MBps CPU usage Disk to Disk w/cp: 64.9 >90% Kernel From my Windows 10 System using IPv4, jumbo frames off: iPerf3: 115.0 >95% Kernel Win Explorer: 14.7 ~75% Normal, ~20% kernel Win cmd copy: 14.7 ~75% Normal, ~20% kernel Win cmd SCP 4.9 ~60% Normal, ~45% kernel Memory usage in all test was <30%What seems to be happening is the CPU is maxed out. Clearly the system can handle the 1 GB network or the disk throughput, but adding them together pushes it over the edge. Are there other hardware parms I can check?
Why StephenB is able to get much higher throughput on the same CPU is a mystery to me. Would you be able to measure any of this on your system. I'm sure it would be enlightening.
It might take a couple days to get to it.
I am thinking it would be good to see the network stats, to see if there are a lot of packet drops (overruns) during the transfer tests. Running ifconfig before and after the test would let you see that.
If there are, then testing with ethernet flow control enabled on the windows machine and switches would be useful.
