SliceTheAir
Nov 05, 2014Aspirant
Duo Backup using Rsync doesn't react
Hi, I have some troubles with my Duo running Sparc firmware 4.1.13 I try to make backups to another NAS over the internet using the in the frontview available options. We use the Rsync protocol....
Nov 25, 2014Guru - Experienced User
Maybe try using top with the command line toggle (with the backup job running) so you can see how the backup job command line compares with the terminal session?
You are not using the rsync over ssh add-on correct?
