SliceTheAir
Nov 05, 2014Aspirant
Duo Backup using Rsync doesn't react
Hi, I have some troubles with my Duo running Sparc firmware 4.1.13 I try to make backups to another NAS over the internet using the in the frontview available options. We use the Rsync protocol....
SliceTheAir
Nov 25, 2014Aspirant
StephenB wrote: Maybe try using top with the command line toggle (with the backup job running) so you can see how the backup job command line compares with the terminal session?
How do I do that??
I checked after I started the job with a terminal session using TOP if I saw a process called rsync. I don't see it...
StephenB wrote: You are not using the rsync over ssh add-on correct?
No I'm not. What is the "big" advantage? Safety, but why and how.
mdgm wrote: You got the slashes the wrong way around in the destination. In Linux \ is used to e.g. escape a space.
I wonderd that. I noticed the difference ofcourse. But giving your suggestion as destination ("/BackupMark/fotos/") it says "unkown path" . With the \ in stead of / it says "connection OK"
But after playing around I aslo tested "BackupMark/fotos/" so without the first forward slash. Than frontview says the connection is OK aswell.
Well the result is what I was looking for. Now I see the proces running in TOP and the log files contain data.. :)
So thanks a lot.
Mark
