SliceTheAir
Nov 05, 2014Aspirant
Duo Backup using Rsync doesn't react
Hi, I have some troubles with my Duo running Sparc firmware 4.1.13 I try to make backups to another NAS over the internet using the in the frontview available options. We use the Rsync protocol....
SliceTheAir
Nov 28, 2014Aspirant
So It's isn't completely solved.
Backup is running on a schedual. First time I did a complete backup wich was succesfull.
Now the first one, incremental with new data gives an error
Itried to search the internet but I can't find a reason for such a message. Can anone help??
Grz
Mark
rsync: writefd_unbuffered failed to write 4 bytes to socket [sender]: Connection timed out (60)
rsync: connection unexpectedly closed (3731 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at io.c(605) [sender=3.0.9]
Grz
Mark
