benwrigley
Dec 15, 2013Tutor
Duo Performance and lockout
Hi All, I've been reading up a lot on performance issues that people are having but none seem to quite match mine. I apologise if I've writing about stuff already covered, but the performance troub...
Dec 15, 2013Guru - Experienced User
The OS partition on your system is /dev/hdc1 (you can also cd /usr and df . -h) 70% free space is of course fine.
WDC green drives go give a high load cycle count, unless you use the wdidle to adjust the timeout. I've never done that on my NV+ (which is using 4 WD20EARS drives). Load cycle counts are about 400K, but I haven't seen any performance issues.
Is this the first time you've seen this performance drop?
