benwrigley
Dec 15, 2013Tutor
Duo Performance and lockout
Hi All, I've been reading up a lot on performance issues that people are having but none seem to quite match mine. I apologise if I've writing about stuff already covered, but the performance troub...
benwrigley
Dec 19, 2013Tutor
Hi StephenB,
I thought that the disks spinning down might be causing the inaccessibility, but no :(
Which log file would you look in for info? In messages I see entries for:
<code>Dec 19 12:16:22 ReadyNas kernel: LPCH_ACTIVE still on: 10
Dec 19 12:16:22 ReadyNas kernel: 2req = 1 8b1e02e8,00000000,00000000,00000000 1</code>
Yes, I am using wired connection to a gigabit netgear router but the squeezebox and the WD Live I use for streaming are only 100MB so I've actually set the network settings to 100 full duplex for now but no ready difference.
When it locks out, it does so for several minutes and it's not always all protocols and probably only once ever 90 mins (not regular though), so it really feels like the Duo is 'doing something' that slows it down...
Thanks
B
Thanks
B
