benwrigley
Dec 15, 2013Tutor
Duo Performance and lockout
Hi All, I've been reading up a lot on performance issues that people are having but none seem to quite match mine. I apologise if I've writing about stuff already covered, but the performance troub...
Dec 19, 2013Guru - Experienced User
Do you have any addons running other than squeezebox?
TCP retransmits (or more properly the lost packets that provoke them) generally result in a massive rate back-off on the affected TCP connection. So a slow ssh connection is plausible.
Since you have ssh, maybe try using top to see what is running, and what the CPU load on the NAS is?
Is it possible that this backup is provoking the bad behavior?
1 win 7 machine is always on and has a share from the Duo mounted for online backup service livedrive
