benwrigley
Dec 15, 2013Tutor
Duo Performance and lockout
Hi All, I've been reading up a lot on performance issues that people are having but none seem to quite match mine. I apologise if I've writing about stuff already covered, but the performance troub...
Dec 20, 2013Guru - Experienced User
Just to make sure I have the facts right:
(a) duo v1 running 4.1.13
(b) xraid (raid 1) disks on the HCL
(c) only squeezebox and transmission installed
(d) jumbo frames disabled, normal MTU of 1500
(e) normal redundant volume status reported in frontview.
(f) plenty of space on the OS partition
(g) no SMART errors reported
(h) modest TCP retransmissions reported
(i) intermittent very slow transfer speeds in both directions under many circumstances
1. direct connection or through GS108 switch
2. 1 gbit or 100 mbit configuration
3. with 3 different win7 machines and two media players
(j) turning off transmission does not help
(k) top does not show high CPU activity during slow network connection
(l) nothing seen in the logs
(m) a full backup has been created
Does this capture where we are?
BTW, did you purchase the duo around the time you joined the forum? If so (and if you are the original purchaser) then it is still under warranty.
