disney_cjd
Jan 15, 2014Tutor
Duo v1 - help with new choice of HDs please
Hello all I know there are lots of teccie people here who may find my post daft, but I am stuck and would appreciate some help please. I have a ReadyNAS Duo v1. it has 2x1TB hard drives that came ...
Jan 16, 2014Guru - Experienced User
(a) can you still see your data
(b) is the system resyncing?
Note you can see progress by hovering your mouse over the icons at the bottom right of the frontview home screen. Hovering over the icons in RAIDar can give you progress information also.
Don't try to do a manual resync if the system says it is already syncing.
