Kazura
Jul 20, 2012Aspirant
Duo v2, can't do factory reset
I just recently bought a ReadyNAS Duo v2, but when I tried it I got the Corrupt Root message. After this i tried to do a factory reset, but either I am doing something wrong or the factory reset doe...
HERBIEO
Are you sure you have a Duo v2 how to tell look here > http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
if you do have a Duo v2 intructions for factory reset here > http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
