Kazura
Jul 20, 2012Aspirant
Duo v2, can't do factory reset
I just recently bought a ReadyNAS Duo v2, but when I tried it I got the Corrupt Root message. After this i tried to do a factory reset, but either I am doing something wrong or the factory reset doe...
mdgm-ntgr
Jul 21, 2012NETGEAR Employee Retired
So is it a Duo v1 or a Duo v2?
This suggests you could have a bad disk or bad memory.
Have you tried running the memory test?
