wolfpacks101
Sep 14, 2012Follower
Enabling Jumbo Frames breaks Frontview
I have same issues with my ultra 2. After enabling jumbo frames, front view wont finish loading until i do an OS reset. This has happened sometimes and other times it is ok. There have been other...
mdgm-ntgr
Sep 14, 2012NETGEAR Employee Retired
What version of RAIDiator are you running?
Have you enabled Jumbo Frames on your PC's NIC and on your router/switch? Have you verified that your router/switch and PC's NIC support Jumbo Frames? Are your PC's NIC drivers up to date?
Are you using Cat5e or newer ethernet cables?
Also some routers/switches and PC NICs may support Jumbo Frames but not the full 9000 MTU. You could try setting a smaller MTU than 9000.
Is you client PC/Mac connected via ethernet or wireless to your network? If by wireless do you still get the issue if connected via ethernet?
