Keligh
May 24, 2017Tutor
"Err: could not properly extract"
Hi, When I logged in the admin frontview interface, I was signaled an available update to 6.7.3 (currently running in 6.7.1). I accepted, download finished and it proposed a reboot. I accept...
- May 24, 2017
For USB Boot Recovery one would need to rename the standard OS6 firmware to RAIDiator-x86-something and put it on the 4.2.x USB Boot Recovery key. USB Boot Recovery with 6.7.3 would not have helped here.
It looks like your volume is mounted read-only. Is your backup up to date?
Edit:
USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available! would have helped thoguh with legacy systems there is the risk that a side effect can be run into when you do USB Boot Recovery that requires a manual fix. If your system has already been fixed I would still suggest updating to 6.7.4 normally using the web admin GUI.
jak0lantash
May 24, 2017Mentor
If you want to check the logs since the last boot (download the logs from the GUI), look at systemd-journal.log and search for the last instance of "jenkins@blocks". Search for clues from there.
You may also check in initrd.log if there is any error related to the firmware update.
Keligh
May 24, 2017Tutor
NAS cannot boot properly anymore (since at every boot, it begins with "updating FW" etc etc ... :(
How can I check those logs ? tech support mode ?
