Keligh
May 24, 2017Tutor
"Err: could not properly extract"
Hi, When I logged in the admin frontview interface, I was signaled an available update to 6.7.3 (currently running in 6.7.1). I accepted, download finished and it proposed a reboot. I accept...
- May 24, 2017
For USB Boot Recovery one would need to rename the standard OS6 firmware to RAIDiator-x86-something and put it on the 4.2.x USB Boot Recovery key. USB Boot Recovery with 6.7.3 would not have helped here.
It looks like your volume is mounted read-only. Is your backup up to date?
Edit:
USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available! would have helped thoguh with legacy systems there is the risk that a side effect can be run into when you do USB Boot Recovery that requires a manual fix. If your system has already been fixed I would still suggest updating to 6.7.4 normally using the web admin GUI.
Keligh
May 24, 2017Tutor
It seems Netgear guy finished his work, NAS rebooted and everything is fine (and in 6.7.3)
However, I don't know yet what he did or what was the problem.
But it's solved :).
mdgm-ntgr
May 24, 2017NETGEAR Employee Retired
Edit:
- KelighMay 25, 2017Tutor
True, I was too enthousiastic before. No, my backup is not fully up to date (mainly because I just became aware that the built in amazon drive tool didn't do his job properly) so I was in the process on completing it (yeah I know, doing an upgrade with an incomplete backup, that was a stupid move)
I didn't see that the volume was readl only at the time (to my defense, It was 2am :) ). Was it made that way when you did the repair or is it a unexpected side effect ? It's shown a read/write in frontview.
Also it seems a balance started, but stuck at 0%.
Should I order a restart from frontview ? Or just complete my backup while I can ?
I wasn't clear but while waiting for the next recommended step, I'm of course completing my backup. Should be done within a 5-6 hours.
- mdgm-ntgrMay 25, 2017NETGEAR Employee Retired
It looks like the balance didn't work. I tried a balance.
You could try copying your data off the system.
