flaviocb
Jan 05, 2018Aspirant
Error putname+64 & strlen+10 on RN104 after upgrading to 6.9.1 when doing aggregation eth0+eth1
I upgraded my RN104 system from 6.4.1 to 6.5.2 and then directly to ReadyNAS OS 6.9.1, everithing worked fine, but because I had to do a OS Reinstall while on 6.4.1 to revcover my password. Teh I ha...
- Mar 15, 2018
Hello, today I were able to update the FW to the ReadyNAS to 6.9.3 and I were able to do the Link Aggregation again. I used the option for the Adaptative Load Balancing and it worked fine. I just had a minor problem the 1st time I asked the RAIDar to open the Adminstratior web page, something was wrong and I had to manually put 192.168.0.114/admin/ so it worked perfectly.
I have one question about something that was mentioned in this thread: how much can I expect in average in performamce improvement by using the new functions implemented by Netgear ? (I understand that to get this advantage I have t reformat all volumes and reload the data)
Best Regards, Flavio
flaviocb
Hello Stephen, thank you for the reply. Yes I can survive without the bonding for some time despite the lower performance when transfering a lot of files.
Is there something I can supply to help the debug of this problem ?
Best regards,
Flavio
