Paul_Thomas
Dec 26, 2016Aspirant
Error using MS Edge browser
I recieve the error below when I connevt to the nas admin page when using the edge browser. Other browsers seem fine.
All firmware/software is upto date. I think this started following the windows 10 anniversary update. Once the error is ignored everything seems to work fine.
Is this a problem with my setup or a general problem with the edge browser?
Show log gives no further details, the details button gived the following
I'm not seeing that, though I am using 6.6.1 beta.
Do you have any apps installed? Do you see this error also with Chrome?
- Paul_ThomasAspirant
Hi,
It works fine with chrome, firefox & IE. I anly have the Plex app installed.
I've just tried the connection from another PC (using edge) and that works fine too, so it looks like an issue with Edge on my laptop, Not sure if its related, but I can't follow links from gmail using edge on the same laptop.
- JennCNETGEAR Employee Retired
Hello Paul_Thomas,
Mine is also working with MS Edge on Win10. Have you checked if you get the same results when you try to open your router's admin page?
Welcome to the community!
