hussVLC's avatar
hussVLC
error with rsyn 7077010012
Dear community,
I am reaying to setup with my readnas102 a remote connection to server to backup, using the remote rsync but I get teh error above, and as I run a test with putty to connect to server it works fine, it is just form the nas I am not being able to connect, any suggestions?
  • well the idea was with SSH but we started with simple RSYNG, on the remote server it is active as the support from the hosting company confirms. And for theh SSH they imported the SSH Key but even with that done we get the error to connect, what are we missing?
      • hussVLC's avatar
        hussVLC
        Thank you, I made sure there is a trailing slash and no initial one, but no change, still error in connection
    • StephenB's avatar
      It might be easier to troubleshoot this if you use the linux command line instead of the NAS backup job.  Once you get the basic folder copying working, it should be pretty easy to get the NAS backup job to work.
      There a lot of things that could be wrong.
      • hussVLC's avatar
        hussVLC
        i did test using putty, but I dont have the knowledge how to use linuex from windows oto program the tasks
  • StephenB's avatar
    hussVLC wrote:
    any suggestions?
    Are you trying to use rsync, or rsync over ssh?
    Have you checked that rsync is enabled on the remote server?
ProSupport for Business
