lukecolb
Feb 19, 2018Aspirant
Expand lun past 8191GB Readynas 2100
Hi I have ReadyNAS 2100 v1 with 4 6tb Disks in the disks are currently mirrored so i have 10tb usable. however i can't expand my lun past 8191GB its says the expensation is complete but just stays s...
lukecolb
Feb 21, 2018Aspirant
Hi
I've put them here
(Removed link)
Thanks
Marc_V
Feb 21, 2018NETGEAR Employee Retired
Hi lukecolb
As we have mentioned there's a possibility that expanding LUN past 8TB might be a limitation for a Legacy NAS with 32-Bit Intel CPU such as the ReadyNAS 2100.
Have you tried disconnecting users connected to this LUN? You can do that by disconnecting or removing the LUN from the LUN group that users are accessing then try to expand and reconnect the LUN.
