willy134uk
Aug 01, 2012Aspirant
extracting rars with duo v2
hi is there a easy way of extracting rar files with the duo v2 ive read you can do via ssh but to complicated ive connected via ssh using telnet but dont know what to do from there
thanks mark
thanks mark
- mdgm-ntgrNETGEAR Employee RetiredYou should familiarise yourself with Linux commands such as cp, ls, mv, cd etc.
To install unrar
apt-get update && apt-get install unrar
To unrar say "fred.rar" in the "media" share.
cd /c/media
Then use the unrar command as described in its MAN page (you can google for the MAN page). - codarz360AspirantHi,
I've been trying for the past 3 days to install unrar via SSH on my ReadyNAS Duo v2. I'm using the Terminal.app on my Mac to connect through SSH.
I've updated the repo's by using thesudo apt-get update
command which updates my default sources.list fine.
When I try to install unrar by typing:sudo apt-get install unrar
I receive the message:
"Package unrar is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'unrar' has no installation candidate"
Here is my current /etc/apt/sources.list file:
# deb http://ftp.us.debian.org/debian/ squeeze main
deb-src http://ftp.us.debian.org/debian/ squeeze main
deb http://security.debian.org/ squeeze/updates main
deb-src http://security.debian.org/ squeeze/updates main
deb http://ftp.us.debian.org/debian/ squeeze-updates main
deb-src http://ftp.us.debian.org/debian/ squeeze-updates main
If anyone can help me out it really would be greatly appreciated. - mdgm-ntgrNETGEAR Employee RetiredYou would need to add lines for "non-free" in addition to your "main" ones.
unrar is in the "non-free" section. See http://packages.debian.org/squeeze/unrar
Not sure whether or not unrar would install on the Duo v2 but you could give it a try. - codarz360AspirantThank you very much for making me aware of that and it has now resolved my issue.
A note to anyone else that has this issue - ensure that you have the line:
in your /etc/apt/sources.list file.
deb http://ftp.uk.debian.org/debian sid main non-free
Then just run asudo apt-get update
- this will now update the new packages.
Then typesudo apt-get install unrar
and BOOM problem solved!
