Ellone
Aug 20, 2015Tutor
Factory reset also format disks ?
Hi, I had an issue with my RN 10400 recently bought. I played with the parameters to add a friend as user so he can access it. I finally managed to do it. But then I couldn't access my own nas ...
vandermerwe
Aug 20, 2015Master
Well when you select factory default, there is a message that says "Factory mode wipes out all data...." This, plus the need to type the word "FACTORY" ensures that it has to be a deliberate action on the part of the user.
You could contact Netgear support and ask them about data recovery services. It costs money and there will be no guarantee of success.
In essence I think you have lost all your data.
Backups are strongly recommended.
- StephenBAug 20, 2015Guru - Experienced User
Regrettably you confused "factory reset" with "OS reinstall".
