ShadowStorm
Dec 27, 2017Aspirant
Factory Reset RN102
Started having problems with the RN102 Nas and it not being detected ofter installing the OS6, thought that the OS might be corrupted or did not install propperly so tried to reinstall the OS with th...
- Dec 29, 2017
If you aren't seeing it RAIDar (when diskless), that does suggest a hardware failure.
Have you checked your warranty status? The warranty is 3 years for the original purchaser.
ShadowStorm
Dec 28, 2017Aspirant
It's done the same thing before the factory reset and not showing up on the network and RAIDar.
Im thinking there is a hardware failure but i just want to make sure before getting a new NAS and seeing that it has no display ports i cant phisicaly look at whats wrong
Dec 28, 2017Guru - Experienced User
Try booting up diskless, and see if RAIDar can find it when you do that.
- ShadowStormDec 29, 2017Aspirant
Just tried that and its not showing up on RAIDar nor on the local network, at the moment after starting it up the Power Light and Disk1&2 alternating.
- StephenBDec 29, 2017Guru - Experienced User
Well if its a hardware failure theres really not much I can do about it.
Although its funny that this happend 1 month after the warrenty expires.
